Aluminum Surface Speeds
Usual preface, I’m with PreciseBits. So while I try to only post general information take everything I say with the understanding that I have a bias.
Surface speed (SFM) matters outside of the chipload. You can compensate some for it but you can not carry heat away from the surface speed side with a chip.
I’ll try to explain this in a non-techno babble way. However, that means it’s going to be slightly more understandable with slightly less accuracy. So take this a way of thinking of it more than exactly what’s happening and I’m not going to go over ALL parts but some critical parts.
One big place where the surface speed comes into play is at the edge of the cutter where it engages what will be the edge of your finished cut. The higher the the RPM the faster this edge is rubbing and the more heat is generated there.
Additionally, the thicker that edge is, the lower the rake, or the more tool material rubbing behind the flute, the higher again the heat gets. These also can create a non-cutting force on the tool and material. Either the heat or this force can cause chattering/squealing or damage the tool/material. That is what we are trying to control with the surface speed (SFM). It has nothing to do with the chipload (feed).
The cutting also creates heat. Assuming that you are within good surface speeds and chipload this is where most of the heat is produced. It almost all comes from the deformation of the material into the shape of the chip (inside the flute instead of outside like the surface speed). Generally speaking the thicker that chip is, the more mass is available to “sink” the heat into from the deformation. Meaning that the higher chiploads product less in general.
So to summarize and answer the original question. Yes, it was probably too fast (surface speed) and eating the tool or effecting the cut. There are times when that’s worth it though. To determine if it is too fast depends on a bunch of things you are probably not going to know (rake, relief, edge radius, carbide grade, etc.).
Hope that’s useful. Let me know if there’s something I can help with.
