@jwoody18 Jeff: I love the ingenuity of this, but it does look like something you do because you simply must see if you can get it to work, rather than addressing an issue. Iām sure any of us can change a bit manually faster than this changer does. Iām not saying that I wouldnāt build one if I could, though.
Iām assuming that this would only work when using a software-controlled spindle, yes? The spindle is turning when it first grabs the bit, then stops when the collet nut engages with the nut holder, then starts while the wrench lines up with the flats on the spindle, then stops again to tighten the collect. That could not work with my Makita router, for example.
I noticed the same thing about the spindle spinning. Although I thought in his very first video that wasnāt the case, but I didnāt go back and check. I thought his original design with the gator grip to hold the endmill used a rotation through an arc to lock and unlock the bit.
Iām half way through a four hour large indexed cut. I would say homing switches are more valuable than the ATC at this point. Mine should be here tonight, hope I have enough electrical skill to figure them out. Iām afraid, having had to stop overnight half way through the job, that once I move my piece and reset my XY (I had to use front left as the stock is too large to use the corner finder) that I can still get good alignment. But I had a bit slip during the cut last night and I think I may have lost my XY or had it shift. Dohā¦
@jwoody18 Jeff: Like you, my next upgrade to the Mill will be homing switches. I have the switches, the wire and the capacitors. Now, I need to make mounts for the switches. Iām thinking that this will be more time consuming than difficult (Famous last word.)
When you say āindexed cutā do you mean what is also referred to as ātilingā. The piece is bigger in Y that can be cut without moving it?
I donāt have any capacitors, doh. I thought it was resistors I needed for noise suppression? Maybe I misunderstood? Hopefully I can get it working in concept and then figure out what I need to make it āproduction readyā.
Yes, tiling is a better word. I am using index pins to cut an almost 5ā worktop that is quite detailed. I can only do ~800mm at a time on my 30x30 one I subtract for pins and a few other things. Iām documenting the process in detail and will share it when done - but must note itās using Fusion 360 although Iām sure you could adapt the concepts. To make things more complicated, I donāt have a 5ā piece of stock so Iām doing about 80% of it in one piece of contiguous 1" baltic birch then I have to cut the last 20% from a different location on the same piece and join them together in assembly. Hopefully I can get good alignment on my joint, not very experience with my biscuit joiner yetā¦
I also did a lot of thinking and calculating and design work on upgrading my wasteboard to allow indexing and generally repeatable cutting that Iāll share once I am happy with it.
@jwoody18 It sounds like a heck of a challenge, Jeff. Iāll be really interested to see your process. In VCarve, there is a tiling function built in. I have not yet used it, but looking at the videos, it seems to make things pretty straight forward.
As to capacitors, Iām sure that you can test everything without them. From what Iāve read, they are just an added feature to filter out noise.
Iāll be posting as to how I make out with mine. I hope to at least start in a couple of days. The bit thing for me will be mounting the switches.
I think itās fair to say itās built in to Fusion 360 but I donāt think itās nearly as obvious. All makes logical sense once I documented the process, but boy do you need to keep track of details relative to what youāre physically doing. That is to say I spent a lot of time staring at my wasteboard and calculating and thinking and moving things. To be fair, though, I am trying to use a grid pattern of 3/8" holes I put in my wasteboard specifically to reference. If youāre just going to cut holes for the indexing pins each time, that saves some complexity.
I look forward to your update. I have the same issue with mounting and just posted a new topic under Add-ons requesting that any design update incorporate some kind of standardized accessory approach. I donāt have a 3D printer⦠but I do have a CNC. Some kind of attachment points that can be easily exploited by woodworkers with a CNC would seem the most appropriate. Something with 14-20 bolt holes or threads and/or 14-20 t-track rails (for example along the very top of the Z assembly, for vac hose hooks, camera mounts, who knows what) would be most welcome.
