Will shortly be setting up my new LongMill and rotary - and was hoping to get some input on best practices regarding things related to table setup, wiring, computer to run gSender,etc
- if possible, should the router and/or dust collection vacuum be run on a different circuit than the LongMill control and connected PC?
- tips on grounding the LongMill and related
- best cables for connectivity
- is there any benefit to a desktop vs laptop for gSender (and can gSender run in background while using vCarve)
- any pros/cons from a gSender perspective to Mac vs PC (or Rasberry Pi perhaps?)
- if locating the control box under the table, any routing paths that should be avoided? Can cables be extended and if so any shielding needed?
- while not βneededβ - if you were to do it again would you get a spindle from the start? And if so, which one?
Just trying to head off as many potential problems from the start of possible
