Bits get blisteringly hot doing even simple jobs
I’ve noticed this since day 1 on my MK2 (using Makita router and bits from Sienci).
Can run a simple job hogging out some pine (eg. Pocketing out a few 6" x 6" squares x 1" deep) following Sienci’s Feeds and speeds database (I have it imported into Vectric and always double check against their pdf’s to make sure it’s the same when setting up toolpaths).
The hogging out generates what appear to be good size chips, no obvious burning, etc…
The bit and collet/nut get insanely hot. Like up into the 80-90+ Celsius territory.
For what it’s worth, I have tried brand new bits and they behave like this too so I don’t think this is due to dull bits.
Wondering if anyone has any input on effective testing I could do to try getting this running cooler.
UPDATE
So perhaps I have a router problem…?
Just running the router (no load) for about 15 minutes, the shaft and collet nut hit 70+ Celsius…not sure how hot they should get with no load on them but that seems kinda hot for no load
I don’t know the answer to your question, but just doing general woodworking, the blades and bits get hot just from normal use when I’m making multiple cuts or drilling. I was taking a long screw out of my table the other day with an impact gun, twirled it out, grabbed the screw, and it was hot enough i had to drop it. So I think something like a router bit which is constantly working may get a bit hot. I may be wrong but that’s what my brain says based on prior experience without testing. Possibly the router is getting hot?
Yeah, friction is a bitch! I expect things to get kinda hot but my understanding is that if chip size/load is correct, the chips will carry away a bunch of the heat (unlike an unscrewed screw that relies on air cooling…and your fingertips :smiley: to dissipate the heat) leaving endmills comfortably hot.
