It will be painted cowboy blue with white lettering.
Actually made two, first one with a 60° V bit took eleven hours, cut a second with a 1/4" End mill to remove the background took a little over two hours.
I had issues in v carve pro using circles and node editing to align to create the curves, as you can see additional sanding required.
