Trying camlabs and a 3d cut for the first time. I believe I got a file loaded and saved and put in UGS. However it is real small. How do I enlarge it
If you click on the object it should turn green and a toolbar at the bottom will appear. In that toolbar on the left you’ll see a readout of the objects dimensions in mm, and in the center ‘scale’ if you change any of the ‘1’ entries to a number larger than 1, it’ll scale it up and if you set to anything smaller than 1, it’ll scale it down. Just make sure the ‘uniform’ box is checked and that you hit the ‘enter’ key after you’ve typed in the new number
