Can not lift up while drilling
I have tried to operate with CAMLab today
Please this picture after down and drilling
What parameter is wrong. Please tell me.
@tomoac What CAD program did you use to create the design?
I designed it by FUSION360
I also tried to make a .nc by CAM of FUSION360 , But UGSP said command error.
How do I output .nc by FUSION360. I also want to know that
@tomoac There are fusion360 users here that I’m sure will help you.
I am curious, though. Why are you using CamLab when you have fusion360? Fusion360 is a cad/cam program, so you can design your project in it and output the gcode directly from it.
It looks like your zero started too low, the bit was cutting into the wood from the get go.
