Christmas Contest 2021
Name: Custom Made Prayer Kneeler
Usecase: Make a unique that can be flat pack and assembled for Christina Charity Event
Material: Birch Plywood, Stain, Mini Magnets
Cut Time: 1.5 hrs
Finish Time 1-2 Days with sanding and finishing with stain and seal coat
Lessons Learned: Original design was handmade using electric hand tools total time took about 3-5 days. New design is repeatable and only take less than 2 hours to cut and you can get 2 on a 4’x8’ sheet of ply. No Screws are required part fit together with glue. Each piece is replaceable and design folds up vertical to save space and stays closed with magnets. Its tricket to get Plywood dimensions perfect especially for inserts and inconsistancy in center sheets especially if material is from big box store. Long mill helped to get from 3-5 days of manufacturing time to make 1 to less than a day to make 2.
