Chucky's Projects: cutlery tray and use of height mapping
@elbarsal I bought mine off Amazon. The one that had next day delivery for me was CNCTOPBAOS. People here have mentioned PGFUN. If you try to avoid Amazon, check diycnc.ca. They have one for $70 but shipping and taxes brings it to the same price as Amazon.
Amazon has the probe from anywhere between $70 and $135 with free shipping on some of them and they will take a credit card. DIYCNC charges extra fees if you want to pay with a credit card. If they also charge shipping then Amazon is substantially cheaper (for the $70 version).
DIYCNC ships from China, with Amazon you have different vendors shipping from different locations (check delivery time)
I think I didn’t do a correct search on Amazon when I bought mine and I paid a premium price
 dooohhhhh
@Chucky_ott Is this the one that you have, CO?
@gwilki Yes, that is the one.
I was told that it was better to get the normally closed version so that if anything becomes disconnected or wire breaks you would know immediately since it will then be “open”.. whereas with a normally open version you wouldn’t know until manually testing to verify it works.
@DavidB Perhaps. I don’t know enough to have an opinion. But since it plugs into the TLS port, and the TLS is normally open, I wouldn’t want to have to invert pins in software every time I switched.
David, you are correct in that a normally open sensor failure only shows up when actively testing. I believe that the standard setup for the limit switches is to have them normally closed for precisely that reason. When you home, you also test the limits but you wouldn’t want to home for every job (yes, some people do that but with closed loop motors that is overkill).
Safeties such as ‘the enclosure door is open’ must run as normally closed since a broken or disconnected sensor cable can cause loss of people bits.
The sensor for the touch plate or the probe is different. If it was triggered when it goes open circuit, then you would have to use a dummy plug when neither the probe or the touch plate are connected. Also, I believe the TLS and touch plate inputs are run in parallel which would cause additional headaches.
When a limit switch fails to trigger, the carriage hits a physical stop and the system safeties trip. On the other hand, If your TLS or your touch plate sensors fail, the result is expensive. It is (IMHO) essential to test the operation of the sensor prior to doing the actual sensing so that a normally open circuit is quite acceptable.
