I am reaching out to ask for guidance regarding grounding practices for SLB systems, specifically in North America (Canada) where 120V AC is used with Hot, Neutral, and Ground lines. My setup includes an AC Ground for the main power and a DC Ground for the 24V stepper motors, control boards, and accessories along with a 5V and 12V DC power supply. I’ve read that the AC Ground should not be connected to the DC Ground, but I am unclear about the correct approach.
For motor cables and other signal cables, I plan to use shielded cables (shield only connected on one end), but I am not sure whether the cable shield should be connected to the AC Ground or the DC Ground. Additionally, should there be any connection between the AC and DC grounds at any point? I want to ensure proper grounding for safety and noise reduction, but I am struggling to understand the best practice.
Looking for clarification or refer me to relevant guidelines for handling AC and DC grounds in this context? Any advice on how to connect the cable shields would also be appreciated.
Thank you for your help.
