I like it! What size CNC is the table for?
I am in the process of building a table for my new 30x48. I am using the Rockler steel table stands as a base. Very sturdy and come with leveling screws in each leg.
There is one issue with these stands, they are not quite big enough for the 30x48, (55.5") so I had to add an extension on the end to make the 78" length that Sciensi recommends. Waiting for some dry weather to be able to bring my MDF panels home without getting wet.
Looks good. I would recommend adding in some corner braces. The machine likes to “shake, rattle, and role”.
I got some done but not installed yet. Thanks for that.
It’s for a 12x30” set up. Can’t wait to get it delivered and put to use.
I’m with you on that one! Wish you the best of luck with your project.
