Finally got around to building an enclosure for my Longmill. I have sketchup plans that I am happy to share with anyone interested. Still need to add some sound proofing but happy with everything so far.
Based on the amount of help I have received from everyone I wanted to give back a little.
The base is made up of solid oak. The enclosure is a missmatch of plywood, oak and MDF.
I still need to add the door openers to assist with raising the front lid. It is very heavy!!
Below is a list of supplies that I used (I do not get anything from you purchasing for yourself) :
Vacuum Hose:
Retractable lanyards (ended up having to double up on a couple locations due to weight of hose. Used a total of 10. Lanyard attached to eyehook and cable ties around hose):
LED Lights (very happy with the way they lit up the enclosure):
Plexiglass Front:
Hose reducer (Used a hole saw in the right rear corner. Reducer from 4" to 2 1/2". You will have to use the adapters in the vacuum hose kit from Home Depot)
They really worked great. In a couple places I needed to double up so that the weight could be properly supported. But for the price, not sure that you can beat it.
@Milo Welcome to the forum Craig. Lots of good folks that are very willing to help! The forum post you responded to is over a year old. Not sure if they will respond or not. You could try posting a new topic and ask for peoples enclosures for their longmill. You may have better luck with what you are seeking. Just my 2 cents worth anyhow. Again, welcome!
Jake
Hi Folks
Just picking up my Longmill MK2 tomorrow
Does anyone out there wish to share any plans for an enclosure?
I also have some plexiglass sheets to incorporate into it.
Much appreciated!
Craig
