Any good ideas for lights on your router to light up your work area
I found a few solutions on Etsy. This one says it’s for OneFinity but it does come in 65mm. $70 seems a little expensive to me but I’m poor and remember everything costing less
Maybe it will give you an idea to make your own if nothing else.
I did see at least one other on Etsy for around $20 but it was USB powered. Maybe that’s OK if you have a spare USB output and a long cable. The $70 one is 110V with 10’ cord.
Norm, here is a light that I purchased for my router .
@norm Here is another one to consider
https://www.amazon.com/dp/B078SR4JRS/ref=twister_B0CCV1LKZ9?_encoding=UTF8&th=1
FWIW, it’s available on amazon.com and amazon.ca
thanks bought a string and installed myself
@norm DIY is always good. ![]()
