Cutting carbon fiber plate
Hi.
I need to cut shapes out of 1mm carbon fiber plate. I plan to use the 1/16th inch corncob end mills. Can I cut 1mm carbon fiber in a single pass? Would the tool file preset feeds and speeds work?
Thanks
@TMacYOW A quick search brought this up. I didn’t read enough to know if it is relevant to what you are doing.
Thanks. He says up to 3mm can be done in a single pass, and I think LongMill is a more powerful. I guess the next step is to try!
-Tom
@TMacYOW Note that he also says not to use an end mill.
