Downloading Sienci Labs tool database
I purchased 3 tool sets from the website and downloaded the tool database into Vcarve Pro 12. When I click on any material in the top dialogue box, other than softwood, the tools do not show up in the Sienci list. When I am in the drop down menus in the list, and I click between softwood and hardwood, there are different parameters for the tool ie: depth of cut difference. So when selecting a bit from the Sienci tool list, do I just leave the material material dialogue box at the top set to softwood and select the material and tool from the dropdowns and all will be good? This does not happen with the metric and imperial lists that came installed in the program.
As well, absolute new to this, trying to learn as I go.
I think I have it figured out now. The way I understand is all of the tool data was imported under the softwood material type. So, data was still there for each material but not populated under the proper header. What I did was went under the softwood material header, selected the hardwood bits from the drop down menu and copied that tool into the proper material header, if that makes sense.
