I need to surface an aluminum blank before I cut it. The top has one surface irregularity that I need to eliminate. I wondered if I could use the same end mill I use for surfacing the wasteboard, but that isnāt advisable (itās 1 1/4"). Iām thinking of my trusty 1/4" two flute upcut.
Iāve done some aluminum cutting with an 1/8" bit and it worked well. (Made a very small " throttle body" for a mockup engine). You will have to calculate chip load for your āspeeds and feedsā and may also need cooling solution. I used rubbing alcohol (works fantastically for aluminum). Iāve found the hardest part with aluminum is proper chip extraction/ ejection so it doesnāt clog the endmill. Also if surfacing try to position the piece close to one of the corners of the machine to reduce deflection in the gantries. (There isnāt much but every little bit helps). Iām very much a novice but thatās what has worked for me
