I finally got my first big project done. It is a sign for our local tool lending library.
I still want to stain the part outside the logo with light stand and put a clear finish over it all, but they need it for a trade show by 10 am tomorrow so no time to cure a finish. But hey, I think having a bit of a DIY look to it somewhat fits the organization.
It is a pretty straightforward sign. I sketched the vectors in Solidworks over the image of their logo, and fortunately they used Times New Roman for the font. I had previously done some test carving on the mill using free softwares, but ultimately decided that I needed to go with Vcarve Pro (which had been the plan from the start anyway - I already had an older version that I could upgrade).
I had done all my tests using gSender with no problems. I loaded the .dxf into Vcarve and set up all the toolpaths. I was confident enough that I did not do any test cuts, just clamped the final sign plywood down and started up.
Immediately the errors came. Error 24, but I never saw any problems with the Gcode. I could just hit resume and it would start again, but as I learned when you do that too much eventually you are going to get your bit going off in a straight line in a random direction. I tried all the toolpaths, and repeated some, and discovered the errors were all random.
So I’m banging my head against the wall - the only obvious change in workflow was Vcarve. There was an update available for Gsender, but that made no difference. I had replaced the hose on my shop vac, and just in case it was a static electricity issue added additional grounding. Still no change.
The next morning I decided to try a different sender program. I had thought I read something about sending directly from Vcarve, and discovered Vtransfer. It is the definition of bare bones, and a real pain to manually manipulate the axes. So I lined up my zeros with Gsender, then closed it and opened Vtransfer. And that worked like a dream, no issues whatsoever (except I forgot to set a floor depth for the vbit, and had two points get to transparency thickness from the back. Those got a little CA glue for reinforcement).
So I am not sure what the issue is with Gsender. Vtransfer has no option for resuming, so I would like to have that ability back. Or perhaps I can go with a different software. Either way it felt good to finally make a product for a customer, even if it is a donation.
