use fusion 360 and have all of a sudden started getting gcode ID: 33, 25, 36, 35 errors on my gcode files. Is there a setting in Fusion 360 that I have wrong?
Might be a USB communication issue.
Have you tried running in $C check mode?
thank you for answering. I decided to run some known “good” gcode through gsender to see if I got the same results. Once I got the same errors I deleted and reinstalled gsender and I am back running. thank you for answering.
