Getting ugs to accept and load a g code file
Alright guys, designed a simple v carve sign to practice all these new found skills. generated tool paths. ran a simulation run, and saved the results from that. opened UGS connected and probed zero. went to open and load the file., and i get the file listed in the bottom edge of ugs screen, and just to the right in a seperate box i get a message saying no file loaded. what am i missing.
@lonnie - Just in case did you use GRBL Inch or MM for your post processor? One of those? And would highly recommend using gSender instead of UGS.
grbl inch. kinda worked myself thru that issue. but when i run the file in ugs it puts the file into a “hold”, situation and sends a error message of motion command target is invalid.
being a new build right out of beta , is g sender more reliable and more user friendly than UGS.I am just starting to get my one available brain cell around UGS, and kinda shudder at having to take on another learning curve. lol
@lonnie - It has been fully released, ver 6.4. Not to say it doesn’t have any issues but Sienci has released it to the general public. That tells me it’s pretty stable and a lot of longmill users have switched to it already, including me. Your choice of course.
@lonnie Lonnie:What did the run the simulation run in? Post the gcode if you like and we can take a look at it. What version of UGS are you running?
heyward, first off sorry about starting this conversation then disappearing on ya. short notice call into a job site, just got home now. As for g sender it wont hurt to go take a gander at it. and compare the two. I’ll get on that in the morning .i tried two differant practice files same results. its gotta be something i’m doing. Just cant narrow it done.
grant. it ran in carveco maker. didnt seam to have any issues. end results looked good. so i imported it into usg and set the machine up to run. mill went from "0,0 to about center of material and then froze and sent the file into “hold”. with the above error message.
I’m running ugs version 2.0.7 dec 29 2020. can i look at posting that g code in the morning.kinda been along evening for this old boot and i can hear a bed calling me.
@lonnie Some CAM programs put lines into the gcode that cause UGS to blip. We can likely find if that is the case here by looking at the code.
Why did you move to UGS, Lonnie; If it was working in Carveco? Just curious.
If you are looking for something other than Carveco for your gcode sender, I can highly recommend Sienci’s gsender.
grant, it was my understanding that i use carveco maker to generate designs and g code then export those gcodes to UGS to run the code. Am i mistaken? you might have already guessed i am so new at this cnc thing,( and i have a rudimenturie grasp of computers).too boot. you and heyward43 have been my shineing light and go too people. I am slowly and methodically working thru the fog that this whole thing has created. If i am complicating this procedure please clearify what i should be doing and please be patient. there are days when i get impressed just turning on the computer.
@lonnie Thanks for the kind words, but this time, I failed you miserably. :frowning_face:
I confused carveco with carbide create, I think. Carbide create has a built-in sender. When you said that it ran in carveco, I incorrectly assumed that carveco has a built-in sender, too. I’ve never used it, so it was foolish to make that assumption.
So, you are not mistaken at all. You create your toolpaths in carveco, then send them to UGS, gsender, or whatever sender you use.
None of this verbiage solves your problem, though, so let’s see what we can do about that. Post your gcode when you get time. Also, what post processor are you using in carveco?
ok good to know im not totally out in left field .lol. I Will work on posting that code just as quik as i can. maybe tommorrow. as for post processor with in carveco maker, I’m using GRBL mm.
hey grant here is a copy of that gcode.
Model Name:
sarah v carve #1
File Name:
C:\Users\lonnie\Documents\Carveco\Models\sarah v carve #1.art
Relief Dimensions:
Width: 175.00000 mm Height: 175.00000 mm
Min X: 0.00000 mm Min Y: 0.00000 mm
Min Z: 0.00000 mm Max Z: 0.00000 mm
Material Thickness = 19.0500 mm
Z Zero = Top of material
Machining Time: 34:57:44
sarah v carve #1 - 1/2 60%
Tool: [1] 60.0 degrees V-Bit 1.000 mm dia.
Feed Rate: 100.000 mm/sec
Plunge Rate: 40.000 mm/sec
Safe Z: 19.734 mm
Spindle Speed: 18000 rpm
Stepover: 0.080 mm
Tolerance: 0.025 mm
Allowance: 0.000 mm
Home Position: X:0.000 Y:0.000 Z:19.734
Comments: sarah v carve #1
Finish Depth: 3.175
Feed Rate Length: 2916995.8 mm
Plunge Rate Length: 52824 mm
Rapid Rate Length: 97549 mm
Machining time estimates based on a rapid feedrate
of 0.000 mm/sec and a time scaling factor of 4.00
@lonnie Lonnie: That’s not gcode. They look like the parameters that are set up in Carveco. From this video
I understand that Carveco saves the toolpath/gcode as a .nc file. That is the file that I would like to see. That is the one that UGS or gsender needs to do the actual cutting.
sorry grant noticed the code didnt load first time around , so here we go again.
T1
G17
G20
G90
G0Z0.777
G0X0.000Y0.000
S18000M3
G0X1.404Y4.968Z0.777
G1Z-0.001F94.5
G1X1.447Y5.122F236.2
X1.404Y4.968
G0Z0.777
G0X1.609Y5.427
G1Z-0.001F94.5
G1X1.616Y5.425F236.2
X1.606Y5.428
X1.605Y5.430
G2X1.603Y5.425I-0.002J-0.002
G1X1.605Y5.427
X1.608Y5.427
X1.609Y5.424
X1.640Y5.422
G2X1.604Y5.432I0.006J0.096
pG1X1.603Y5.434
X1.604Y5.432
X1.601Y5.424
X1.599Y5.422
G2X1.609Y5.424I0.006J-0.005
G0Z0.777
G0X2.133Y5.431
G1Z-0.001F94.5
G1X2.134Y5.433F236.2
G2X2.124Y5.428I-0.008J0.003
G1X2.133Y5.430
X2.135Y5.428
X2.133Y5.431
X2.136Y5.432
G2X2.136Y5.438I0.004J0.003
G1X2.135Y5.436
G2X2.108Y5.425I-0.038J0.057
G1X2.137Y5.427
X2.139Y5.425
G2X2.136Y5.432I0.003J0.006
G1X2.139Y5.433
X2.137Y5.441
X2.138Y5.443
X2.137Y5.441
G2X2.084Y5.422I-0.063J0.095
G2X2.139Y5.424I0.037J-0.370
G1X2.144Y5.422
X2.142Y5.423
X2.139Y5.433
X2.142Y5.434
X2.139Y5.445
X2.140Y5.448
X2.139Y5.445art 2
part 3
G2X2.053Y5.421I-0.085J0.137
G1X1.671
G2X1.601Y5.437I-0.000J0.161
G1X1.601Y5.439
X1.601Y5.437
X1.597Y5.420
X1.595Y5.419
X1.597Y5.420
X2.136
G2X2.148Y5.419I0.004J-0.013
G1X2.146Y5.420
X2.142Y5.434
X2.145Y5.435
X2.141Y5.450
X2.141Y5.453
X2.141Y5.450
G2X2.053Y5.424I-0.087J0.132
G1X1.671
G2X1.599Y5.441I0.000J0.158
G1X1.599Y5.443
X1.599Y5.441
X1.593Y5.417
X1.591Y5.416
X1.593Y5.417
X2.136
G2X2.152Y5.415I0.006J-0.018
G1X2.150Y5.417
X2.145Y5.435
X2.148Y5.436
X2.142Y5.455
X2.143Y5.458
X2.142Y5.455
G2X2.053Y5.427I-0.089J0.127
G1X1.671
G2X1.597Y5.446I0.000J0.155
G1X1.597Y5.448
X1.597Y5.446
X1.589Y5.414
X1.587Y5.413
X1.589Y5.414
part 4
X2.136
X2.155Y5.413
X2.156Y5.411
X2.155Y5.413
X2.148Y5.436
X2.151Y5.436
X2.144Y5.461
X2.145Y5.463
X2.144Y5.461
G2X2.053Y5.431I-0.091J0.122
G1X1.671
G2X1.596Y5.450I-0.000J0.152
G1X1.595Y5.453
X1.596Y5.450
X1.584Y5.411
X1.583Y5.410
X1.584Y5.411
X2.136
X2.159Y5.409
X2.161Y5.408
X2.159Y5.409
X2.151Y5.436
X2.154Y5.437
X2.146Y5.466
X2.147Y5.468
X2.146Y5.466
G2X2.053Y5.434I-0.093J0.116
G1X1.671
G2X1.594Y5.455I-0.000J0.149
G1X1.593Y5.457
X1.594Y5.455
X1.580Y5.408
X1.578Y5.406
X1.584Y5.408
X2.136
X2.163Y5.405
X2.165Y5.404
X2.163Y5.405
X2.154Y5.437
X2.157Y5.438
X2.148Y5.472
X2.148Y5.474
X2.148Y5.472
G2X2.053Y5.437I-0.094J0.111
G1X1.671
G2X1.592Y5.460I-0.000J0.146
G1X1.591Y5.462
X1.592Y5.460
X1.576Y5.404
X1.574Y5.403
X1.576Y5.404
X1.584Y5.405
X2.136
X2.168Y5.401
X2.170Y5.399
X2.168Y5.401
X2.157Y5.438
X2.160Y5.439
X2.149Y5.477
X2.150Y5.480
X2.149Y5.477
G2X2.053Y5.440I-0.096J0.105
G1X1.671
G2X1.590Y5.465I0.000J0.142
G1X1.589Y5.468
X1.590Y5.465
X1.572Y5.401
X1.570Y5.399
X1.572Y5.401
X1.584Y5.402
X2.136
G2X2.172Y5.397I0.000J-0.142
G1X2.174Y5.395
X2.172Y5.397
X2.160Y5.439
X2.163Y5.440
X2.151Y5.483
X2.152Y5.486
X2.151Y5.483
G2X2.053Y5.443I-0.098J0.099
G1X1.671
G2X1.588Y5.470I-0.000J0.139
G1X1.587Y5.473
X1.588Y5.470
X1.568Y5.397
X1.566Y5.396
X1.568Y5.397
X1.584Y5.398
X2.136
G2X2.177Y5.392I0.000J-0.139
G1X2.179Y5.390
X2.177Y5.392
X2.163Y5.440
X2.166Y5.441
X2.153Y5.489
X2.153Y5.492
X2.153Y5.489
G2X2.053Y5.446I-0.099J0.093
G1X1.671
G2X1.586Y5.476I0.000J0.136
G1X1.585Y5.478
X1.586Y5.476
X1.563Y5.394
X1.561Y5.392
X1.563Y5.394
X1.584Y5.395
X2.136
uhm little bit late now but, there has got to be a easier way for me to post this code?
part 5
G2X2.181Y5.388I0.000J-0.136
G1X2.184Y5.385
X2.181Y5.388
X2.166Y5.441
X2.169Y5.442
X2.154Y5.495
X2.155Y5.498
X2.154Y5.495
G2X2.053Y5.449I-0.101J0.087
G1X1.671
G2X1.585Y5.481I0.000J0.133
G1X1.584Y5.484
X1.585Y5.481
X1.559Y5.390
X1.557Y5.388
X1.559Y5.390
X1.584Y5.392
X2.136
G2X2.186Y5.382I0.000J-0.133
G1X2.188Y5.380
X2.186Y5.382
X2.169Y5.442
X2.172Y5.442
X2.155Y5.502
X2.156Y5.505
X2.155Y5.502
G2X2.053Y5.453I-0.102J0.080
G1X1.671
G2X1.583Y5.487I0.000J0.130
G1X1.582Y5.490
X1.583Y5.487
X1.554Y5.386
X1.552Y5.384
X1.554Y5.386
X1.584Y5.389
X2.136
G2X2.191Y5.377I0.000J-0.130
G1X2.193Y5.374
X2.191Y5.377
X2.172Y5.442
X2.175Y5.443
X2.157Y5.509
X2.157Y5.512
X2.157Y5.509
G2X2.053Y5.456I-0.103J0.073
G1X1.671
G2X1.581Y5.493I0.000J0.127
G1X1.581Y5.496
X1.581Y5.493
X1.550Y5.381
X1.548Y5.379
X1.550Y5.381
G2X1.584Y5.386I0.034J-0.122
G1X2.136
G2X2.196Y5.371I-0.000J-0.127
G1X2.198Y5.368
X2.196Y5.371
X2.175Y5.443
X2.178Y5.444
X2.158Y5.516
X2.158Y5.520
X2.158Y5.516
G2X2.053Y5.459I-0.104J0.066
G1X1.671
G2X1.580Y5.499I-0.000J0.124
G1X1.579Y5.502
X1.580Y5.499
X1.545Y5.376
X1.543Y5.374
X1.545Y5.376
G2X1.584Y5.383I0.039J-0.117
G1X2.136
G2X2.201Y5.364I0.000J-0.124
G1X2.203Y5.361
X2.201Y5.364
X2.178Y5.444
X2.181Y5.445
X2.159Y5.524
X2.159Y5.528
X2.159Y5.524
G2X2.053Y5.462I-0.106J0.058
G1X1.671
G2X1.578Y5.505I-0.000J0.120
G1X1.578Y5.508
X1.578Y5.505
X1.541Y5.371
X1.539Y5.369
X1.541Y5.371
G2X1.584Y5.379I0.043J-0.112
G1X2.136
G2X2.206Y5.357I-0.000J-0.120
G1X2.209Y5.353
X2.206Y5.357
X2.181Y5.445
X2.184Y5.446
X2.160Y5.533
X2.160Y5.537
X2.160Y5.533
G2X2.053Y5.465I-0.106J0.049
G1X1.671
G2X1.577Y5.512I0.000J0.117
G1X1.576Y5.515
X1.577Y5.512
X1.536Y5.366
X1.534Y5.363
X1.536Y5.366
G2X1.584Y5.376I0.048J-0.107
G1X2.136
G2X2.212Y5.348I-0.000J-0.117
G1X2.215Y5.344
X2.212Y5.348
X2.184Y5.446
X2.188Y5.447
X2.160Y5.543
X2.160Y5.547
X2.160Y5.543
G2X2.053Y5.468I-0.107J0.040
G1X1.671
G2X1.576Y5.520I-0.000J0.114
G1X1.575Y5.523
X1.576Y5.520
X1.531Y5.360
X1.529Y5.357
X1.531Y5.360
G2X1.584Y5.373I0.053J-0.101
G1X2.136
G2X2.218Y5.338I0.000J-0.114
G1X2.221Y5.333
X2.218Y5.338
X2.188Y5.447
X2.191Y5.448
X2.160Y5.553
X2.160Y5.559
X2.160Y5.553
G2X2.053Y5.471I-0.107J0.029
G1X1.671
G2X1.575Y5.527I0.000J0.111
G1X1.574Y5.531
X1.575Y5.527
X1.526Y5.354
X1.524Y5.350
X1.526Y5.354
G2X1.584Y5.370I0.058J-0.094
G1X2.136
G2X2.225Y5.325I-0.000J-0.111
G1X2.229Y5.317
X2.225Y5.325
X2.191Y5.448
X2.194Y5.448
X2.160Y5.567
X2.159Y5.574
X2.160Y5.567
G2X2.053Y5.475I-0.107J0.016
G1X1.671
G2X1.574Y5.536I-0.000J0.108
G1X1.573Y5.540
X1.574Y5.536
X1.521Y5.346
X1.518Y5.343
X1.521Y5.346
G2X1.584Y5.367I0.063J-0.087
G1X2.136
G2X2.235Y5.302I0.000J-0.108
G2X2.324Y4.978I-12.677J-3.646
G1X2.329Y4.977
X2.327Y4.978
X2.194Y5.448
X2.197Y5.449
X2.158Y5.585
X2.155Y5.602
G2X2.090Y5.484I-0.098J-0.023
G2X2.053Y5.478I-0.036J0.098
G1X1.671
G2X1.573Y5.545I-0.000J0.105
G1X1.573Y5.550
X1.573Y5.545
X1.515Y5.338
X1.512Y5.333
X1.515Y5.338
G2X1.584Y5.364I0.069J-0.079
G1X2.136
G2X2.237Y5.286I-0.000J-0.105
G1X2.321Y4.975
X2.331
X2.333Y4.974
X2.331Y4.975
X2.197Y5.449
X2.200Y5.450
G2X2.070Y5.912I24.295J7.070
G1X2.152Y5.608
G2X2.053Y5.481I-0.098J-0.026
G1X1.671
G2X1.573Y5.556I0.000J0.101
G1X1.573Y5.562
X1.573Y5.556
X1.509Y5.327
X1.506Y5.321
X1.509Y5.327
G2X1.584Y5.361I0.075J-0.068
G1X2.136
