Grbl 4th Axis on Sainsmart 3030
I have a Sainsmart 3030 Prover and have just picked up the true 4th axis that was produced for it as well as a few other of their machines. The firmware on my machine does have values for $103, $123, and $133. The machine also has a 4th axis mode that can be enabled or disabled in the on-board controller screen.
I have been using gSender with this machine for a year now and love it. I even purchased the Auto Zero touch probe and wired it to work with this machine. I would love to be able to use it for 4th axis files as well and am hoping that this could be a simple fix to allow 4th axis on certain Grbl firmwares.
I have done a small amount of testing but haven’t had time to get more into it. If I choose grblHal as the firmware, the 4th axis selector shows up properly and allows me to spin the A axis. I haven’t tried running anything with grblHal selected as the firmware, so I don’t know if I could just run it like that and ignore the fact that I’m unable to edit firmware settings with the wrong firmware mode selected.
I have looked into flashing grblHal onto this controller board, but I don’t think that is going to be possible because Sainsmart doesn’t provide enough documentation about the board besides knowing it is an Arm 32 processor.
Would it be possible to run a firmware check to see if the A axis settings have values, and if they do allow the 4th axis to run with grbl firmware? I would also be open to any other suggestions. I can do any testing needed or provide any more information to help make this work if need be.
Thanks.
Edit: Forgot about one other thing. With the new gSender Edge and the way the firmware is being auto detected, I am going to be unable to switch the firmware mode back to grblHal when the Edge features are rolled into the main releases.
Hi @COden6484, as of the newer 1.6.0 Edge versions and soon coming to the 1.6.0 main release you should now be able to toggle on Rotary functionality for regular grbl boards so that you don’t need to use the workaround of using grblHAL :+1: I hope that does what you were looking for, we got a couple pieces of feedback on it so we’re happy to finally have it in
If you see any other issues with its implementation or functionality, just open up a new topic to let us know
