GSender GCode View
I dont know, must have gone totaly stupid here but,
WHERE??? is the G Code viewer? There should be a code viewer where you can see for example if you need to start on a specific line you should be able to check the G Code and what line to start of from. I have NO WHERE where I can see the actual code???
Here’s a link to the one I use to review GCode.
Thx but what Im looking for is if there is an INTERNAL g code viewer in G Sender so you can see what line it’s on etc. Not external, any text viewer can view the g code.
Click the console tab in g-sender after you load a file, is that what you are looking for?
