OK, I need some help. I am new here but not new to computers.
I just got my LongMill set up and did a successful test cut of the test sheep file. I was also able to successfully fun a job created in Easel. However I am on a Mac and love the features in Carbide Create. So here is the problem:
I create a job, Set the material size and thickness and I have set the thickness zero height to “Top”. I save the toolpaths and then extract the gcode using the new “extract gcode” webpage and then upload that to my laptop connected to the LongMill. I then zero the tool using the Auto Zero Touch Plate. The tool performs the check and moves it to the lower right corner of the workpiece. When I run the job, the LongMill plunges deep into the workpiece and starts to move. I am sure this is a setting some place but I am at a loss. Can anyone help me out here?
Thanks in advance for your help.
Lou S
