I need some serious help and I figured that there are a lot of great people on here. So here goes.
I love my Longmill! It’s amazing! I wasn’t really in love with the noise of the Makita router so I decided to get a water cooled spindle. I ended up with an Amazon special. its a Huanyang 2.2 kw with Huanyang VFD. It is 110V verison. its what i have right now and no access to 220v.
i have found alot of wiring videos for 220 but not much for 110v. i need help with that and i also need help with the parameters. i am brand new to the spindle world and really dont know much about what i am doing.
i have gotten it to spin the correct way however it doesnt seem to spin at 24k rpms and i keep getting a code of eoaa or eola and it shuts down the spindle.
the spindle is a GDZ-80-2.2c and the VFD is hy02d211b.
i would REALLY appreciate the help as i have no clue what i am doing and i am getting to the point of just going back to the Makita.
thank you all so much!
i have set it all up using your instructions however it keeps popping up eoaa after 5 seconds. i currently have no control with the dial as well.
do you have some pictures of the wiring inside that is for the green terminal blocks?
thanks for your help so much.
Hey Blunderpunk - saw your thread and I was curious what brands/manufacturers/sources you were using for the spindles you’re testing. I was thinking of an 80mm water cooled but haven’t done a lot of research into it yet.
Thanks!
Any luck with your setup?
I am able to follow blunderpunks guide and get the spindle running via the VFD. But cannot for the life of me get it to work within gSender.
