One of the issues I have is forgetting to turn off the power to the controller (i.e. press the oops switch). I would like to wire an indicator light across that switch. What voltage is going through the switch? I tried checking, but was getting some strange results.
Are you measuring in AC or DC Volts?
I donβt know for sure but most βoopsβ switch Iβve come across are in the AC supply.
@Mique FWIW, I wired a car tail light LED to the 12v output jack on the LM controller. I have the old controller without the panic button.
I tried measuring both.
I tried a different multimeter and it measured 60 VAC with the switch off, 0 VAC when on. Hmmm!
If you are measuring ACROSS the switch, then I would expect 0v with the switch ON.
