I created a small inlay project using Carbide Create Pro. However, G-Code does not insert a Pause to allow for tool changes. What is the best solution to this?
I don’t know CC, but you more than likely need separate G code files for each tool.
I use ncviewer.com and separate the two tools into individual files. Let me know if you need more detail.
In CC, I believe you can edit each individual Tool/toolpath portion. As an example: disable the second, third etc and when 1st is finished change tools and then disable first and re-enable second and so on.
