I have installed an IOT relay switch and connected it to the Longmill board. I then tested it with the M8 and M9 commands…everything works great.
I have 2 questions and If someone could find me a solution:
- can the M8 and M9 commands be inserted somewhere so that they automatically repeat at every job
- if option 1 is impossible to do , how to manually insert the M8 at the start of the job in the Gcode. When I type in the command M8 and press return it positions itself at the end of the job. How can I put it at the start of the coding.
I design in Easel and then transfer the gcode in an nc extension to import it in the GSender
