Landed 20 piece project
Greetings!
With health issues keeping me from aggressively chasing business, I had this project land in my lap. I made a family a charcuterie board to be used for a wedding guest registry. It was a challenge getting a finish on the board that could be written in with a sharpie. I sampled a few finishes, found one that would work and that the family could add a few additional coats after the guests signed it, making a lasting memory. Finding a “food safe” finish was not possible as putting it on afterwards smeared the sharpie signatures. Here is the finished project and the poly spray I used.
The father of the bride owns a post frame business. He reached out months later and wanted to give plaques to all new building owners. According to him, that will be around 20 per year.
I made him a proof of concept on a scrap piece of walnut and he approved. This one will go into his office to showcase the “barn warming” gift. The scene was AI generated and I used a 90 degree V bit carved at .2” depth. After painting and sanding with 320 grit sandpaper, it has a coat of spray polyurethane (same as I used for the charcuterie board). Cleaning the image up was quite a feat, as there was a lot of “digital junk” in the image. I have a few other AI generated images that could be used as well. I also asked him for an image of an architectural drawing so I can play with carving an actual image of the customers building to see how it turned out.
Ultimately, after 6 more thank you gifts, my LongMill, my Vectric VCarve Pro and my design computer will be paid off. That is a good feeling!
Thanks for looking!
Jake
@Jake Very nice work, Jake.
Those are really nice! I love the barn warming one. Nice work on getting your mill and software paid for.
You are having better luck with AI generation then I’ve had. I should give it another shot. I tried to have an AI generate a cribbage board and it couldn’t even get the number of holes right or make them all the same size. :man_shrugging:
AI is not the answer really. It’s all about asking the right questions and I just got lucky. I did AI images for the raised dog bowls for both my 4 legged friends. It took 4-6 attempts to get what I was looking for. Still not perfect, but it did work. As I said above, there is much “digital noise” that does nothing for the image, and there are too many to remove all of them. I also think it has to do with what tool you use. I have had the best luck with Microsoft Designer. Specifically, I ask for ink or line drawings. If you would like me to give it a try for you, I would be happy to. Let me know!
Jake
True, I read somewhere that asking the right questions to an AI is an art form unto itself. Like anything I’m sure it some practice.
Taking a closer look at the barn one and I see what you mean, looks like there are rocks in the tree! I still like it and didn’t notice the noise at first glance. I’m sure if it was hanging on a wall somewhere it would look fine.
Thanks for the tip about about Microsoft Designer, I think I’ll give that one a try.
Greetings! I hand delivered two plaques today. It totally warmed my heart when I went in and in the company’s office was my first plaque proudly on display.
I was told that they are booked out with building projects till the end of 2025. I probably will do a different design for the next ones.
Hi Jake,
Those are a lot smaller than I imagined. You must have mentioned how large they were in your first post but my mind goes “yeahyeah” when it encounters inches and translates it into meters or something. I bet you can relate.
Anyhow, I’m impressed even more now that I can see the actual size against the staggering detail you’ve mannaged to get out of a 90deg Vbit. I need to revisit this asap.
Anyhooo, I may risk boosting your ego somewhat but I had the oppertunity to be present at the livestream Chris did, and these plaques you made got a shoutout. Chris mistook them for another technique and you can take that as a huge pat on the back.
They are indeed awesome like that.
FFW to 2h33m mark.
Thanks @Spamming_Eddie! That did bring a smile. So your post made me a bit jealous! I wish I was close enough to go to Sienci Labs myself. I would enjoy rubbing elbows with the folks who make this all possible. Their product is outstanding, and in turn makes this forum a genuine pleasure to be associated with.
Thanks again!
As I reside in the EU, I am always an ocean away from Canada.
Nonono, it was a live stream on youtube, and normaly anything that is live streamed from the americas is way to late or way to early for me to attend so I was very pleased when this one went live in my vacation and I was able to stay up late to follow it from start to end.
It was prolly the last time too.
So no, I was not at tha Lab. I wish!
@Spamming_Eddie oh okay!:+1: For some reason I thought you were in Canada. That makes this forum even cooler! EU is a long ways away from the cornfields of Iowa, USA! I appreciate you and what you bring to our little corner of the world.
Jake
