Laser Beam Power Supply Dead?
I received my Laser Beam from Sienci a couple of months ago. Just now getting around to hooking everything up. Everything is installed, wires ran, plugged in the power supply. The light on the brick came on. Turned on the driver, it lit up and the fan started after turning on the key and pushing the reset. I turned everything off, unplugged the power supply, and went to lunch. When I came back and plugged the power supply back in. There was no light on the brick and the driver will not turn on. Am I missing something, or could the power supply have died while I was at lunch?
Hi Randy,
I just turned on my laser, made it whine the fan and turned off the power. Turned the power back on and behold, my light on the brick was off too.
I pressed the reset button and the whole thing came back to life.
You might have tried this but you didn’t say you did, so maybe that was the missing step?
Welcome.
I did try resetting. Sent a support request to Sienci. Got a reply in less than 24 hrs that they are sending a new power supply.
Thanks for the help.
