I probably selected the incorrect laser setting when I purchased the Vectric Laser Module,
For anyone that has the Sienci Laser what are the tool settings in VCarve . My settings are attached, but when I try and preview toolpaths, no matter what I set it to, I get nothing.
Thanks.
The preview seems to make the laser toolpaths very light unless you cheat and make the power or passes higher in your toolpath than what you want to burn at.
I suppose your settings are close enough to get started, but I’m just wondering what toolpath settings you are using.
@Spectre180 Andrew: You may also want to try changing the colour of your toolpath in the preview to black.
