I have been searching for a way to do double sided milling using Fusion for some time. I did not want to use the dowel method because that is only suitable for an occasional project (IMHO). If you have many different work pieces and each has dowel holes in different places, you soon have Swiss cheese as your spoil board unless you use a secondary spoil board every time. I decided that this was not practical and would likely take extra time during the job. I was certain that there must be a way to do this without dowels and eventually I did find the secret sauce.
I use dog holes on my spoil board and I used 3D printed dogs for a super precise fit. These were used to locate the jobs to the same x/y position. I used eccentrics to lock the work piece in place. I ran into an issue with registration between the two sides and I had a hard time figuring out why this was.
Today, the light came on ā¦ā¦ when the job is clamped this way, it moves slightly! The dogs either deform (I am currently printing solid dogs as a trial) or they shift ever so slightly when clamping force is applied. The net result is a shift between the two sides of the job. I think the error is additive as well so if the registration is off by 0.5 mm on either side, there will be a 1 mm position error between sides.
I thought it would be worthwhile to post this issue because on occasion there are posts about double sided prints not registering correctly.
As I said, I will try solid plastic dogs next (I donāt like the idea of steel dogs next to my milling cutters) but it might be time to screw a solid fence onto the spoil board any time a double sided job is planned.
