LED strip odd behavior Altmill/SLB-EXT - RING works, RAIL is white
I was having the same issue with my rail light staying white. I added just a 330 ohm resistor to the data line on the SLB side and it works for me now. no cap .
I’m glad I found this post. I have the same led strips and having about the same issue. I ran 18g shielded 3 wire from the controller to the rail and still have issues. randomly 1 to 5 leds will work but with random colors. I have some different led’s coming in tomorrow. I’ll try those and if they do the same thing i’ll add the resistor and cap.
Welcome! Try the series resistor first (its easy) and if it doesn’t work, add a capacitor. The cap is there for the spike current draws to keep the brightness levels the same - not really a problem for the AltMill gantry lights…
Thanks everyone, adding the resistor fixed the issue.
