I just successfully finished my first extended job (10+ hours). Thought I would put together a compilation of lessons I have learned since getting my Longmill, mid October 2020. Most of these lessons are from this forum (Thank you all). I wish I had bookmarked where I found each item to make your journey easier. If you have issues, read, and post questions, someone WILL help. Once you learn, pass it on.
ASSEMBLY
Take your time. Check and double check your assembly.
After assembly, on first cuts, I found that the y rails were off by 3/16 front to back. I took the machine off of the waste board and realigned. Now within <1/16”, side to side and diagonally.
Tight but not too tight.
I was having trouble maintaining the xy position between tool changes. Troubleshooting led me back to the forum. Based on suggestions I loosened my anti-backlash blocks, adjusted the v-wheel tension. I ran the machine back and forth, full on all axis. With y full back, both sides. I tightened the blocks and set the adjustment screws finger tight.
TOOLCHANGE
XY axis off after tool change
I was still having occasional issues maintaining xy on tool change. Back to the forum. One post mentioned that both wrenches should be used to change the bit. Yep, I was using the button on the router and one wrench, moving the xy slightly.
Another post suggested using $1=255 grbl setting to keep the stepper motors enabled. I set up 2 macros, one to lock ($1=255), another to unlock ($1=100). No more xy shifts.
POWER
Check your power.
I would get into a cut and the controller would “blip”, stopping the job. I first thought there was an issue with the controller. Not. I have an older home. The one outlet in the shop was flakey. I took this opportunity to run two new lines, on separate breakers. No more issue.
JOB SETUP
As of now, my standard setup for a job
- Clamp down material.
- Run y all the way back, both sides full back.
- Lock axis ($1-255)
- Set job zeros.
- Run job, only reset z zero on tool change (leave xy alone and use both wrenches)
- After all cuts complete - Unlock axis ($1=100)
- Run y back full for next job.
- Clean up machine and area.
So far the cuts are near perfect. I have much more to learn!
I hope this helps someone.
