LongMill MK1 Inductive Front Left/Y Sensor loose
Hello!
Using the LongMill MK1 with the inductive Sensor Kit from its first iteration.
Realised today that the Sensor on the left Front (Y Sensor) was a bit loose.
Took it out to assess the situation.
Saw that the threaded inserts were a bit loose.
Removed them, then squeezed a but of CA Glue in the hole then reinserted the tiny inserts.
This does not seem to be strong enough.
Obviously, the inductive Sensor is not in any danger to fall out of to get bumped by the machine movement, but would like to get this a but more tight.
Any ideas?
Maybe try epoxy? Filler to get twenty characters.
Interesting…
Will see what i got, or have to purchase.
I just worry about the not yet cured epoxy spilling IN the Internal threads of the insert.
Or maybe i have to temporarily fill/block the internals while gluing and remove this once cured.
Will think about it…
