Lost COM6 connectivity 45 minutes into a 1:45 carving
@BMcNanley I am likely not the best source of advice on these question, Bob. First, I don’t have the Sienci laser beam. I have a very similar diode laser. I don’t have a spindle on my LM, and I have my laser connected the PWM port on the SLB, just as I did on the original long board. So, I don’t need to change any firmware settings going from router to laser. Finally, I never followed the advice to set $30 to 255. I hasten to add that I am not saying that is/was bad advice. I understand where the number came from. (That may well not be true since I understood that the 255 had something to do with how many increments an 8-bit controller running grbl could read. Since I believe that Sienci continues to recomment 255 on a 32-bit controller running Hal, I am likely mistaken in my understanding.) That aside, maybe my math skills aren’t what I believe them to be, but I always found that setting $30 to 1000 made my life much easier when determing my power settings. (1000 is Lightburn’s recommendation, for that that’s worth.) A 50% power setting equates to S500 in my gcode, 30%=300, etc. Using 255, a 50% power setting renders either S127 or 128. I rest my case. :grinning:
All this meandering aside, if I can be of any help, I’m willing to try. With luck, though, someone with a Laserbeam who is following this thread will be of my help than I can be.
@BMcNanley, since you’re still having issues without much response, I’d again suggest sending us in an email so that we can help you more effectively. The Forum format is typically best for simpler or more generic problems or questions, whereas email or phone tends to work much more quickly towards solving more individualistic issues. Plus, if you do end up resolving the problem there’s nothing wrong with coming back to the forum and letting everyone else know what other things you tried and how you resolved it if others want to learn from your experiences :+1:
