I think my next project is going to be making some coasters with small scraps I have laying around. I’m going to be making some that are a chaotic end-grain pattern, in part to learn the technique so that I can put it to use on bigger more expensive lumber for cutting boards.
Since the panels I’ll be gluing up are too short to run through my planer, I was thinking I could surface the panels at the CNC. I surfaced my wasteboard simply by jogging the machine, and that was ok, but tedious.
Is there an easy way to setup a surfacing operation in Carbide Create, or another CAM app? If another app, which would you suggest? I’d love to build up a library of different surfacing toolpaths saved for different dimension panels and depth of cut so that I could just load up the best one for what I’m surfacing, and let it rip, er, surface.
