Making G-code with FreeCad
I’ve been learning to use FreeCad, and I’m getting close to creating G-code, but I’m still not getting it right after quite a bit of time. I have a Longmill 30x30. Can anyone explain to me how to do it? Thanks
@EricJ Welcome to the group, Eric. I’ve moved your post to the software help topic. I believe that it will get more attention here.
I’ve never used FreeCad so, unfortunately, I can’t be of any help.
It may help if you can provide a few more details. When you say that you are not getting it right, what is happening? I assume that you are creating a CAD drawing, then CAM tool paths. Is that right? From there, at least in other CAD/CAM applications, you create gcode, using the appropriate post processor. Where are you in that process if, in fact, that is the process in FreeCad?
Hey Grant,
Thanks for responding.
Yes, that’s right, I’ve created a part and I’m trying to create a cutting path. FreeCad isn’t logical in a lot of ways. LOL, it’s a great tool to have I think, but it’s not easy to use.
I’ve been able to make a cutting path that looks like it’s cutting my project, but on the simulator its cutting above my project. At one point I had it cutting it out most of the way right, but the starting position was in the middle and not at a corner like I need it to be. It seems like I’m close, but I’ve been at it for hours and haven’t figured it out yet.
Thanks again
I know FreeCad a bit but don’t have a ton of experience with the Paths bench. I was able to change the origin from the Job Edit screen. On the setup tab with the vertex you want to be the origin selected use the X=0, Y=0, and Z=0 buttons.
Feel free to ask more questions in this thread and I’ll help if I can. :grinning:
I have a little test file I’ll keep to help out but if you are willing to post the FreeCad file here or in a Private Message to me I might be able to help more easily.
thanks! yeah there’s nothing special about the file. I’d appreciate any help you can give. I did figure out how to set the origin in path workbench. I’m trying to cut this 2D part out of 2" styrofoam.
Dang, they won’t let me upload a file. Oh well, thanks anyway!
Will it not let you upload a file at all yet or is it the file extension not excepted? It won’t let me upload a FreeCad file either but if it’s the extension problem you can zip it and then upload.
I had it zipped and it wouldn’t allow that either because I’m a new member.
Hey thanks for trying to help. I walked in this morning and my first attempt I got it to work. I guess I just needed to sleep on it! LOL
Anyway, i’m off to cutting! Thank you!
