Homebrewing is one of my hobbies, so the longmill with a laser has been a fun addition. No more boring chalk board tap handles. Now I need to build a shelf to hold all of the various tap handles as I try new beers.
Yep, this is my latest one. 1/8 bit for the pattern cutout, v bit for brick face, laser for burning the shield. Can’t see it now, but the shield has a tenon on the back and the castle face has a mortice so I didn’t have to worry about alignment.
I have made them in components the body, tops, and center plates are all separate. It makes them much easier to post process and paint. I have 3 printers a Wahoo Duplicator, A JGAuraora, and a Tronxy A5s, These were built as giveaways at a beer festival my brew club attends.
These are great!
You have a laser installed on your longmill? That is something that I really want to do in the future so that I do not need 2 devices. Can you give a little info on your laser? I know that there is another thread on here that has a laser installation, just curious if you did the same.
My unit is a Sansmart unit. Others have gone with a Bangood unit and some with the Endurance models. Lots of good info in the laser posts.
It works great now, took some tuning. Grab some resistors in case you need a pull down, my unit sourced so much current/voltage that the longmill couldn’t pull it down to 0 on the PWM pins.
