MK2 Spoilboard Layout
Just figured I’d share this since everyone who has seen how I laid out my spoilboard and T-tracks seems to like the idea:
In the past, I’d gone ahead and cut segments for the upper spoilboard layer in equal parts, as is typically done. While that was easy, it often seemed like I found the T-tracks to be a little too close together or a little too far apart for what I was trying to clamp down, especially on those pieces where there’s only a very tight safe zone for clamping. So I came up with a way to give myself lots of options.
I start with the usual 49” wide piece of 0.75” thick MDF, but rather than cut equal pieces I cut them various widths like this:
There will be a piece left over that’s just over 8” wide, exact width is determined by the kerf of your blade when making all the measured cuts. I just rip that piece up the middle to make two pieces that are roughly 4” wide.
I then rabbet 1/8” along the underside edges so that I can lay them over the T-tracks to give them a little extra strength as many folks do. Finally, I lay them out on the supporting layer of MDF in this order:
4” T 7.5” T 4.5” T 3.5” T 5.5” T 4.5” T 6.5” T 7.5” T 4”
The result is that the centers of the T-tracks are apart from each other by 8”, 5”, 4”, 6”, 5”, 7”, and 8”.
Those are the givens, but also by adding 4+5 I get 9” apart, 4+6 gives 10” apart, etc., all the way into the teens. Not that I actually count how far apart the T-tracks are from each other, but it makes it much easier to lay out where I want to clamp a project down so that the clamps are close enough to get a good grip on the wood yet not so close as to risk getting chewed into.
And that’s it - hope it’s useful for someone else too!
