A friend of mine recently asked ‘can you do mountain ranges?’ and I said yes, without having actually done any long-form relief carving before, so there was a bit of learning to do.
Using my Altmill with Sienci ATC, I first faced the cookie flat on the back side, then the top side, and once the blank was ready. Note: the cookie was very dry and well-aged, so I didn’t have any issues with cracking or warping.
Added a little water, to see the colour.
Next step was to program the job. The final use case here is a coffee table, so the cutout will get a 12" x 16" piece of 0.25" thick glass. I designed a 0.25" deep pocket to fit that glass and added +0.030" for clearance, then added dogbone corners. I also added a 0.125" lip around the perimeter.
Full disclosure: I work for LightBurn Software (hello from your friendly neighborhood Support team), so I’m using MillMage, which (as of a few hours prior to this post) just released MillMage 0.9, including our Pro features like V-carving and relief milling, which I use here. I don’t want to shill too hard here, but if you’re keen to read more, I’ll leave this link. Back to the project.
The mountain range comes from Maker.Studio - which will soon be integrated into Web Tools to run right from within MillMage, but for now I pulled in the enormous ~200MB .stl, then converted it to a depth map.
Roughing strategy
For roughing I used a 1/4" diameter 2FL Downcut square endmill, with a 1.25" flute length.
I set a top height of 0.25" (below the lip for the glass) and a depth of 1.5", with 0.25" DOC .040" radial WOC. 18000RPM, Feedrate 140IPM
With roughing complete, we’re on to finishing
Finishing
Using a 1/16 tip 10deg tapered ball mill, 1/4" shank
Full 1.25" DOC
.010" Stepover (4%)
22000 RPM
Final result
Final thoughts
The Altmill with ATC is working great, and didn’t skip a beat on this ~5.5hr USB streamed final pass.
I’ve attached my 4x4 Altmill w/ATC bundle if anyone else wants to give MillMage a try. The ATC runs entirely with Sienci’s-own macros via the firmware so it’s super reliable. At this moment we don’t have the Autozero touchoff plate built-in, but you can still use it for Z touchoff. Soon it will be a 1 click ‘use this tool block’ preset.
For those wondering, the mountain range is near the Goat range, just a few hours from where I live in the Kootenays of BC.
Next up:
Altmill 4x4 w ATC.mmzip (10.7 KB)
I 3D scanned a guitar from a local crafter, and I’m going to replicate it to near-net shape so he can produce more of them.
Let me know what you think or ask away if you have questions.
