Dang Altmill sticker on the gantry is slightly crooked! Ill bet mine was built on a Friday and they were all sitting around slugging Moosehead beers! Now I donāt mind a slightly crooked decal but Im a little miffed that I did not get a couple Mooseheadās in my orderā¦seems like a reasonable thing! On a lighter note, coming over from a Shapeoko, I was simply amazed at the built in squaring tool. I remember having to loosen and tighten screws for a couple hours to get the Shapeoko square. Heck, 5 minutes and a couple button pushes and the Altmill is doneā¦simply amazes me!
Hmmm ⦠I didnāt even know that āsquaringā was a thing for the Altmill. I guess I should re-read the installation manual.
Yes, a crooked sticker is definitely a problem. I would have a chat with support and see if they have a suggestion. Maybe they can send you out a new sticker?
Ah, looks like I did the squaring after all ⦠I think ā¦
@beerbarrel you have no idea on how much a crooked sticker would bother me
lolā¦heck with the stickerā¦I want a moosehead!
I donāt have a sticker on my mill, so if it was in the shipment, the chance is that it ended up in the meh chest having no clear function.
You can have it, but it will take some time to dig it up. I donāt keep scores on what ends up when in there. Itās a pile.
Are you serious? It is very slight. I just mentioned it to make light of it. Its one of those things you have to stare out for 20 minutes to see. Its like when you make a project and have a screw up in it and it glares out at you but nobody else can see it.
Yes I am. A bit ocd for things like this. I put labels on about 100 small parts drawers and all of them are perfectly straight. Even the slots for the screws on our switch plates are oriented in the same direction ![]()
But at the same time, Iām a bit messy. So thereās a constant battle between the chaos and the OCD in me.
lolā¦so you are one of those people!..too funny!
Actually, the people that donāt do that are āthoseā people.
lolā¦touche!!!
Had to get 20 characters there!
⦠but are they oriented in the correct same orientation? ā-ā or ā\ā or ā|ā - which is the right way? ![]()
Real precisionists call themselves CDO - it is like OCD, but the letters are in the correct order!
you should be able to buy extra Altmill stickers in the store
Agreed, but the real question is do they sell Moosehead!
