Need acrylic info and assistance
I put a similar post in the Facebook group today but got no response. I am getting ready to try my first acrylic cut. I ordered 3/16" acrylic. I am going to paint one side. I have plans to cut circles using O flute and label circles using a diamond drag bit.
However, I have not a clue what speed or feed rate to use with the O flute bit. I have read enough that I know it is rather important so as not to melt the material, wasting the material and possible the bit, too. Not sure what depth to run the diamond drag, but I feel like I can play with those settings more safely that the cutting.
Either way, ANY direction would be greatly appreciated!
@OriginalChrisPratt - Don’t give up Chris. I know there are a few that have worked with acrylic. I saw your facebook post but I have not tried acrylics yet. I bought some in different thicknesses to give it a try myself. Just waiting on warmer weather since my garage/shop is not heated. @gwilki - Grant can you help this gentleman out. I know you have cut some acrylic before for your magnetic dust boot. I can’t help him. I am interested in the info too. Thanks in advance.
@OriginalChrisPratt @Heyward43 I’ve cut up to 1/4" acrylic with an o-flute 1/8" bit. I also cut 1/2" acrylic with a standard 2-flute 1/4" bit. In both cases, I ran the Makita router at 12000rpm - number 2 on the speed dial. I set the feed to 30ipm and the plunge to 20ipm. I did ramps of .5" inch for both bits.
I was surprised at the quality of the surface.
I’ve cut quite a bit of 1/2" corian using the same numbers.
You are right, Chris. The big thing is finding a speed that does not chatter, but moves fast enough to prevent melting. Acylic varies quite a bit, too. There are more chemical names that I can spell, but to us, it all means how hard it is and its melting point. This is just me saying that YMMV over mine.
I have absolutely no experience to help you, sorry. I’m just wondering if you have a link for the drag knife you are using, would love to get more adventurous and try acrylic also,
https://smile.amazon.com/gp/product/B07DK1TWKG/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
That is the link for the diamond bit I purchased…have not used yet…
@Heyward43
Wow! Thank you so much! That’s exactly what I needed…a place to start. I agree–so many different chemical names…kinda like Kleenex. Everything is called Kleenex but Kleenex is actually a brand. I did do enough research to make sure I bought cast acrylic and not extruded. A bit more expensive but hopefully more forgiving of my inexperience.
Greatly appreciate the help (from both of you!). May take a couple of weeks to get to it now (shared garage with Harley, which decided to break down today), but once I make the piece, I will let you all know how it worked out.
Thanks again!!
