I have started a XL spreadsheet with these categories: Download and Install; Security; and Application Usage. For the install, it would be nice to have a trusted certificate tied to the software, my TrendMicro AV initially blocked the install (Windows, had to run as administrator and trust the Exe). App usage: I like to also run on a system that is not connected to the CNC to visualize the gcode, but this software does not connect to a com port first to visualize on my machine that is not connected to the controller. Also, I switched to inches, but still see Dimensions and Feed Range in MM.
