Just downloaded the latest version of Gsender. Now the Longmill will not go to 000 position, cannot zero any of the axes with buttons and the auto touch probe is not working. The x,y and z movement buttons still work. To get the machine to show xyz at 0, you have to manually move the spindle to the desired position then shut down the SLB and turn it back on. Any solutions? Thanks
Found the post concerning the $10 EPROM settings, especially the value for the Work Coordinate Offset. All my parameters were set to OFF. Reset to the values recommended in the post and everything is back to normal. Problem solved. Thanks.
The new version “start from line “ everything moving ultra slow. I’ll have to go back to the previous version.
Has this issue been resolved?
