Actually, Iāve broken 2 2mm end mills in the last 2 days when the āpreciseā Z- jog suddenly moved roughly 10mm down hard into the stock. I consider fixing this thoroughly and quickly a very high priority. Not being able to rely on the jogging is a killer.
Iāve been doing the jogging by clicking directly on the UI. I have an application called ātouch portalā that can send key stroke sequences to gSender, but it gets less reliable with each revision to gSender. Iāve temporarily stopped using it, waiting for some stability to return.
I thought that perhaps the mouse was at fault, and switched from a wireless mouse to an older wired mouse. That had no effect - I broke 1 end mill with each one.
