need some advice on getting my laser back up after upgrading to the slb- ext board. Cant seem to get it to run through the new board. Verify where it plugs in as well as settings. Thanks in advance
Hey UD,
Welcome to the forum. Since you didn’t specify what your previous controller was/is, it’s a bit hard to co e up with straight answers. I can however direct you to some pages that might help you figure it out on your onwnsey.
Found here in the specs section.
Assuming you use g-sender at all, here’s the section of the maual covering laser.
Hope this helps a wee. If not, help us help you.
