For those of us using a larger (heavier) spindle (I have a PWN 2.2 80mm) we need to have $212 set so that the spindle doesn’t drop due to the weight. From a safety perspective this voltage to the z-axis should be maintained in the event of a panic button push as the spindle will be spinning for several seconds after activation.
@jpnharris I believe what you’re asking for here is a change to the SLB firmware, correct?
I would guess it is firmware, maybe software but panic stop wouldn’t allow a spinning bit to drop uncontrolled, I don’t like to use the panic stop much but it does happen. On at least two occasions work piece was ruined by falling spindle.
For grblHAL set $37=4 to keep the Z driver enabled. However, I am not sure if SLB estop cuts power to the drivers - if it does then it will not work.
@terjeio on our older branch, it seems hitting the E-stop disables the $37 holding on the motors. If that’s not the current behaviour then completing our update to Main should resolve this issue. Thanks for chiming in!
