The actual gcode. At least the first 20-30 lines. I don’t know how to do that.
I did solve the problem though. Since the other files worked I decided to redo the file that wasn’t running. Apparently I was doing something wrong in creating the file. So this time it ran. I’m not sure what I messed up in creating the file so I can’t say.
Thank you for your help!
So the past couple of days I have been trying to create afile that would run in Gsender. This what I do.
Create a New file-Job set up -single sided-Job Size-7.0,7.0, 0.74 inches. z zero -material surface-XY datum position x 0, y 0-click ok -create vectors-circle-center point x 0 y 0-Diameter 6.5 Inches-create-close- Switch to toolpath command-material setup-set-thickness 0.74 xy datum center=z zero- material gap above model-0.0 -rapid z gaps above material-clearance 0.2-plunge 0.2-home start position x 0,0, y 0,0-z gap above material 0.8-click okay-material setup set- 0.2 z.0-0.74-toolpath operations-profile toolpath-2Dprofile toolpath-cutting depth 074-tool end mill 1/4"-passes 13-machine vector- on-climb-no last pass-no tabs-check add ramps-zigzag-specify ramp distance 0.5-name “circle 1”-pick the vector-calculate-I get previus -close-toolpath operations-save toolpath-selected toolpath-machine Longmill 48x30-save toolpath-save to progects-Gsender-load file-outline ok-varify job ok-start job. The router goes to the top of the circle and stops.
@Dean I have moved your topic to the Vectric help category.
Post your .crv file.
What post processor are you using in VCarve to create your gcode?
Where are you setting XY0 in material setup. I am assuming that you are setting it in the centre of the material since you are creating a circle with its centre at XY0, but I am a bit lost by your text description. The .crv file will help.
