Good evening I am wondering if there is a way to rotate a project from vertical to horizontal in Carbide Create? I am making a 34x9 flag and I would like to set it up going along the X axis instead of the Y axis.
Thank you very much.
If you mean setting up your base.
I use vetric, but looking at videos it has something. In your job setup just reverse your dimensions in width and length.
If you mean rotating import
@EricMac I don’t use Carbide Create, so can’t offer up any help, Eric. I’ve moved your question to the Carbide Create topic to better raise attention to it. Please post back when you resolve this so that others can benefit.
