Re Starting a file from line
I updated to SLB today. Started a carve and it stop at line 1150. When I try restart from a previous line, the router moves extremely slow. Any body have this problem and know how to fix ?
I seem to remember having the same issue many months ago. My resolution was to either reload the file and use start from line, or power down restart and load file. I cannot remember exactly which worked. I only had the issue the one time.
Thanks. I’ll try both
@Tim1 This has been discussed here several times. Search for those posts and you may find some help. In the end, though, I think that it is an issue when you are using grbl inch as your post processor and need to start from line. It seems to start running in mm per inch - much slower. This has been identified several times in the gSender bug category.
