"ring light" output voltage?
Hello all! I have a super longboard and a ring light for my router. The ring light is 8 led on a circuit board and only one color. It is 24 volts. My question is I cannot find a voltage output for the “ring light” on the super longboard as well as any info on whether or not I can use 2 wires with it as I will not be using an RGB strip.
Thanks in advance for any specs and insight!
@Benjaminjaquith I’ve moved your question to the SuperLongBoard category.
Thank you! Sorry about that
@Benjaminjaquith No worries. I believe that it will get more attention here.
So it appears the output is 5v on the ring light. (I should have known being as it’s for “up to” 8 LEDs).
However, I ended up using one of the “pwr out” sockets after measuring my ring lights draw @ .170 amps (within the . 250amp limit) and use macros to turn it on and off. Brilliant setup guys, I am loving the flexibility on this new board! Really happy with it so far.
@Benjaminjaquith Good plan. I believe that you can set the macro to one of the buttons on the estop to make it easy to turn on and off.
Great stuff @Benjaminjaquith, I’m back from vacation now and should be able to be more responsive to answering questions but your solution is exactly what I would’ve suggested. Glad you’re enjoying the new board!
